TwinTurbo.NET: Nissan 300ZX forum - Yep. That's the one (n/m)
GrecV2
on April 21, 2018 at 7:09 PM
Yes I believe it is near it.
posted by rightzedfred
on April 21, 2018 at 07:38 AM
Revs not dropping immediately to idle...
GrecV2
09:37:49 04/17/18
Re: Revs not dropping immediately to idle...
Bigmatthew86
11:10:56 04/17/18
Haven't checked that, although...
GrecV2
15:14:24 04/17/18
Also not a bad idea to verify the throttle cable isn't
jzack
11:18:40 04/17/18
Very True. I have also seen the PCV hard pipes that come
MixManMash
13:48:20 04/17/18
I just re-did / adjusted TBs / cables. They close fully. (n/m)
GrecV2
14:36:20 04/17/18
jeezus.... that could end badly. (n/m)
MeatMan (604Z)
17:49:51 04/17/18
Yep. Happened to me during a full throttle, full boost run.
MixManMash
08:06:59 04/18/18
Heh. I had linkage on my triple carbs disconnect one time...
GrecV2
16:50:35 04/18/18
I had this happen at highway speeds as well. (n/m)
spicyZ
11:12:56 04/23/18
Plug off your Cold Start Air Regulator.
Cjw3
17:29:16 04/17/18
I did that as well, first as a trouble shooting test; but I
Gordo 96NA Daytona
21:15:22 04/17/18
I'll take a look at this...
GrecV2
21:47:42 04/17/18
It sounds like an issue similar to one I had with my old TT
Gordo 96NA Daytona
21:02:20 04/17/18
Heh. One of the things that I just did was swap ECUs...
GrecV2
21:46:08 04/17/18
Lucky You. ;-) (n/m)
Gordo 96NA Daytona
21:57:38 04/17/18
Metacom
20:10:35 04/18/18
Re: Re: Revs not dropping immediately to idle...
1996 Z32 N/A
06:12:12 04/19/18
Re: Re: Re: Revs not dropping immediately to idle...
Metacom
07:18:10 04/19/18
Insure Throttle Bodies and Butterfly Plates are carbon free. (n/m)
Gordo 96NA Daytona
08:49:19 04/19/18
Possibly a vacuum leak somewhere
LitlElvis
09:22:08 04/19/18
Thing that makes me think that isn't it is...
GrecV2
14:19:43 04/19/18
Re: Thing that makes me think that isn't it is...
Metacom
19:31:36 04/19/18
Spraying starter fluid is a quick and clean way to find or
LitlElvis
18:56:52 04/20/18
Did you check the Air regulator?
rightzedfred
23:02:14 04/19/18
That's the one right next to IACV, right? (n/m)
GrecV2
09:37:18 04/20/18
rightzedfred
07:38:40 04/21/18
Yep. That's the one (n/m) -
GrecV2
19:09:12 04/21/18
